Occasional vibration when cornering hard
I have a relatively new 4.5" short arm lift on my 2010 JKUR. I am swapping out the front drive shaft later this week, hoping that it will correct a couple of things. The main reason I'm swapping it out is because I tore the boot on the front DS off-road, but I've also noticed that when I'm cornering at a little bit higher speed, I get vibration that feels like it's coming from the front drive shaft.
I mainly notice it when accelerating around an on-ramp or slowing from freeway speed off an on-ramp through a loop. I crawled under and looked at the drive shaft but couldn't see any obvious rubbing. The track bar feels tight (relocated with the 4.5" BDS lift).
I don't experience loss of control... it doesn't feel like a full death-wobble that I had with a weak track bar on my old '04 unlimited...
Has anybody else had this rubbing/vibration feel through cornering? I'm hopeful that it's a drive shaft issue since it's going to be replaced this week, but if it could be something else I'd love to know your experiences before I get into the shop. Always good to sound "somewhat" educated before talking to the folks at the shop <grin>.
Backspacing is 4.5". I'm running 35" Toyo M/T's and have quite a bit of room. I don't see any signs of rubbing on the control arms. These toyo's would rub like crazy tho if they did touch with the aggressive sidewalls. Good thought - thanks!
That's good advice. I will drop it out tomorrow and see if the vibration goes away. I'm replacing it either way as it's definitely a problem with offroad performance but I'm too curious to wait.
