Odd brake issue... need help
Old Jan 24, 2010 | 10:41 AM
mmacJK's Avatar
Hey
Well here are the answers to your questions:
The problem is usually from a steering wheel that is not straight/centered.
I had that done at brakes plus, so unless they screwed up it should be straight. Certainly the wheel is straight when im driving straight. Having said that I do have the AEV Procal which i used to reset the speedo.
Sometimes, incomplete lifts can also trigger it.
Did you install all the components with the RE kit, including the cambolts?
Yup everything including the cambolts
Are you sure you got the 2 door lift instead of the 4 door lift?
Yup package says 2 door.
Sometimes, it can be a tire issue.
What is your tire psi?
On 35 MTRs the PSI is 40 on each tire.
Are all the tires new?
100% brand new
Have you rotated in a spare with significantly fewer miles than the others?
Nope, all new tires.
Do you have the specs from the alignment?
Yup here they are (personally, i know nothing about this stuff!)
Front left:
Actual Before
-0.7 -0.8 (camber)
2.6 2.3 (caster)
0.09 0.50 (toe)
12.8 12.8 (SAI)
12.0 12.0 Included angle
Front right:
Actual Before
-0.2 -0.2 (camber)
2.6 2.4 (caster)
0.09 -0.31 (toe)
12.7 12.7 (SAI)
12.4 12.4 Included angle
FRONT:
actual before
Cross Camber -0.5 -0.6
Cross caster 0.0 -0.1
Cross SAI 0.1 0.1
total toe 0.18 0.19
Rear left:
Actual Before
-0.8 -0.8 (camber)
0.08 0.05 (toe)
Rear right:
Actual Before
0.1 0.1 (camber)
0.22 0.25 (toe)
REAR:
actual before
Cross Camber -1.0 -1.0
total toe 0.3 0.3
Thrust angle -0.07 -0.10
Old Jan 24, 2010 | 12:57 PM
mmacJK's Avatar
Will do that today!
I am not finding the steering much different just slightly. Having said that, overall I dont feel a major difference in the drive from my stock rubi.
Ill lower the pressures to 28 now and do a test drive.
Old Jan 24, 2010 | 07:18 PM
mmacJK's Avatar
Ok dropped the tire pressure and went for a long test drive.
I noticed that the steering wheel was not straight as i thought it was post alignment. It may well be that the wheel isnt straight as I was told from the shop.
Ill watch it the next day or two and then redo the wheel.
