Odometer Discrepancy - Tire Size????
Old May 1, 2008 | 06:53 PM
murray8144's Avatar
Default Odometer Discrepancy - Tire Size????
I'm running 34's in place of stock 32's. I know my odometer will be off, but does anyone know by what percentage? I dont want to end up waiting 6k miles for an oil change thinking its only been 4k or 5k
Old May 1, 2008 | 07:23 PM
Vexel's Avatar
Miata.net is a good % calculator.. but, I'm not sure if they do inches.. you'd have to figure out your P/LT size.
Old May 2, 2008 | 05:57 AM
08 Unlimited's Avatar
You will be traveling 6.25 % fasted than what the speedo reads.
Old May 2, 2008 | 06:14 AM
TEEJ's Avatar
Talking
32/34 = 0.941... (Old tire size divided by new tire size)
That's a 5.88 % change down in rpm.
So if you were going 75 MPH true speed, the speedo would read 5.88 % lower, or ~ 70.6 MPH.
If the speedo is reading 70.6 MPH, its off by 4.41 MPH (As the true speed is 75 MPH)
To ADD back to the true speed, that 4.41 MPH is a larger percentage of 70.6 than it is of 75 MPH....so, you need a larger percentage than 5.88% when going back.
34/32 (New tire size divided by old tire size) = 1.0625...so adding 6.25% adds back the missing mph.
As the odometer and speedometer are proportional to each other, if the speedo is off, the odo is off the same percentage.
So, if the odometer says you went 2,824 miles, you'd add 6.25% to that to get the true miles, showing you actually went 3,000 miles.
Of course, the factory 32's are more like 32.1", and most 34's are less than 34", as these are NOMINAL sizes, not exact sizes...and that's normal...but, of course, it makes these calculations an estimate, not a precise projection.
If you take the specs for each tire, etc...you can plug in the actual numbers, and, except for rolling differences, tire pressures, etc...you'll be closer to the TRUTH.
Hope that helps!
Old May 2, 2008 | 07:30 AM
Audi2Jeep
Guest
Posts: n/a
Teej loves the questions.
but i just read that and then my head exploded. maff is hard!
Old May 2, 2008 | 09:08 AM
LinkSync's Avatar
I am on 35s.
When I am actually going 75mph my speedo is showing 70mph exactly.
This only true because the dealer flashed my comp for as big as they can go which I think is 33s but am not sure about that. ASK THEM.
So for me I have a .0667% error on my speedo.
7% error?
PFFFT
Brand new stock rigs of any car, can have as much as 3% error.
What I really like is that I won't get a ticket if I obey the speedo per posted limits.
But I will be speeding.
YEH!
Just a bit tho, and I only do so with out zig zag diving in and out crap that scares others.
But I bet if you got a flash you would never notice any error in daily use.
Luck to u and enjoy!
Old May 4, 2008 | 08:42 PM
aero_instability's Avatar
The MPG calculation is also off
Old May 5, 2008 | 06:46 AM
TEEJ's Avatar
Talking
Originally Posted by putnam dan
Why so complicated
circumference = 2 pi R
32 = 200.96 inches
34 = 213.52 inches
35 = 219.8 inches
200.96/213.52*100=94.1% of true value for 34s (it reads low by 5.9%), 91.4% for 35s (low by 8.6%)
LinkSync, yes you have a close to 7% error
70/75 = 93.3% of true value (low by 6.7%)
Stock speedos' generally read high not low, so you don't sue the manufacturer when stopped for speeding
Um, taking everything you need (32/35) and converting it to circumference, is MORE complicated, not less complicated, you are adding a step for nothing, and getting the exact same answer.
And, yes - the makers tend to calibrate for the LARGEST optional tire, so THAT guy can't sue them....AND, so that you think new rig is FASTER and gets better MPG....and needs SERVICE sooner, and runs out of Warranty sooner, etc.
Old May 5, 2008 | 07:00 AM
bcperry2000's Avatar
For X owners....keep in mind that you didn't start with 32s. i jumped from 29.3 inches to 34.8 which makes for a large difference
Here were my calculations:
Stock tire size - 225/75/16 - 29.3 diameter; 92.049 circumference
BFG tire size - 35/12.50/15 - 34.8 diameter; 109.327circumference
(109.327-92.049) / (92.049) = 18.77%
Then the easiest way to calculate your real mileage or real MPH is:
Mileage x 1.1877 = Actual Mileage
MPH x 1.1877 = Actual MPH
Old May 5, 2008 | 07:03 AM
JCAD's Avatar
wait i have an x and now have 37s on it..what is the difference in speed and miles
