odometer off by how much???
I just changed my gears from 4.10s to 5.13s and I need to know how much my odometer is off. The computer is programmed for the 32" tire 4.10 gears combo, and my current setup is 35" tires and 5.13s. I plan to get the procal... BUT right now I can't (full time college student on a super tight budget), and I need to know my true mileage so that I can keep up my preventative maintenance. Thanks for the help!!!
EDIT: I may be wrong about this. Now that I think about it, I'm not sure the gear swap will effect the speedo. Best to follow Robar's suggestion below. Or get a buddy to follow you down the road and tell you how fast you are actually going.
I have a GPS, but I guess what I need is some formula to calculate the distance I really travel versus the distance the odometer saysI have traveled. I think that my odometer is clocking miles faster than I am putting them on.
In 4th gear I calculate at 65 my jeep should be going 1931 RPM, but instead it is going 2209 RPM. Flip of that... at 2000 RPM I am now going 59 MPH instead of the 67 I should be. So at that speed I would be going 8 miles less than the Jeep thinks I am. So can I divide 59 by 67 and get 88%? So I am going 88% of what I should be? So that would mean that at odometer reading 2640 miles, I have gone 3000 miles and it is time for an oil change? Or would it be that 3409 on the clock was really 3000 miles? Or am I looking at this completely wrong everywhere??? I know there are some engineers on here. Help me.
If it's your maintenance schedule your worried about I wouldn't sweat it. You're spinning your motor harder with the gears and nothing really cares how many miles you're vehicle rolled it's just how much service you've gotten out of the fluids.
That said, I would just take the maintenance intervals off the odometer as it stands. As you're running shy but spinning the motor more it works out about the same.
The final gear ratio has NOTHING to do with whether your speedo is correct or not. The speed sensors at each wheel feed info to the computer as the axles rotate. The computer, "knowing" that the tires are 32" diameter calculates the speed per tire rotations. 1 rotation of a 32" tire covers 100.528". 1 rotation of a 35" tire covers 109.53". So the computer is giving the wrong speedometer speed 'cause it "knows" how far a 32" tire travels in 1 rotation but the 35" is going further. Your actual speed is higher than the speedometer says and your traveling further than the odometer says. In this example that difference is 9.375%.
