OE rubicon locker harness and switch panel
Old May 7, 2008 | 10:16 AM
zekisson's Avatar
Default OE rubicon locker harness and switch panel
Hello guys, finally I got today the OE rubi locker full cable harness and switch panel. Part # JEP 4602508AF and JEP 56055357AF
Is there any one with installation manual? maps? in the front of my sport (x) JK, I have fitted the rubi D44 with the e-locker, rearI ghave the D44 with ECTED inside, how do you think I should use the OE harness? anybody with similar setup? bellow are the pictures:
Old May 7, 2008 | 11:40 AM
atomicmecha's Avatar
wow... that looks like a mess to install. can't help you with instructions or anything, but i am wondering... can you take a picture of that switch pannal from behind before you install it. i am thinking of doing the locker mod on mine and been thinking of trying to re-uses the stock switches but haven't had the time to take them out and look at the rear to see what kind of connector they have.
Old May 7, 2008 | 11:43 AM
zekisson's Avatar
I don't think you can, I thought of it untill I cracked open one switch panel to see an IC and one pulse click base swtich that will be useless to hot wire without being hooked to the computer.
Old May 7, 2008 | 11:58 AM
riverzendz's Avatar
Hmm...that's a lot of harness. The part number for that harness is specific to the Rubi I assume?
Old May 7, 2008 | 12:14 PM
Piginajeep's Avatar
I was debating on wiring my front 44 with that harness., let me know how it works out
Old May 7, 2008 | 12:20 PM
guinness's Avatar
I cant help you w/ the oe harness but it is possible to wire the locker w/out it. I have the front and rear rubi axels on my x and they are wired so that they will engage in any drive setting for the rear and in 4hi or low for the front. They are wired to a few toggles on the dash. I know that doesnt help but possibly an alternative.
Old May 7, 2008 | 12:38 PM
Piginajeep's Avatar
I was thinking of that, But I'm lazy.
Old May 7, 2008 | 08:25 PM
TeraFlex's Avatar
Sponsoring Manufacturer
I bought that same harness when I added my front Rubi44. No way was I going to run that mess of wiring. I just cut the plugs off and ran them to a 5amp fuse to a toggle with a cover on it. Works great, plus I have a spare end in case I break one off.
Old May 7, 2008 | 10:20 PM
Peter R.'s Avatar
Don't touch the harness. The buttons just connect to the ECU which controls the lockers, swaybar and ESP. Any mods should be done to the output of the ECU, possibly by using an interposing relay, but I haven't seen a decent schematic for the JK's yet.
Peter R.
Old May 8, 2008 | 04:18 AM
Piginajeep's Avatar
Peter R.
well if you wire it from the stock switch. it will limit the use of the locker.
