offroad issues with 1.75 lift
Old May 23, 2012 | 01:24 AM
jmpjk's Avatar
Default offroad issues with 1.75 lift
Anyone have an opinion about a 1.75 lift and its mild offroad abilities. Before the comments start rollin in I only need this much lift and its all I will ever need. Ill be running stock 32 BFG's. I am curious to see if I need brake lines relocation brackets, rear trackbar or anything else other than shocks and spacers. Any issues when its fully flexed? Can I still disconnect the front and not ruin the shocks? What all should I worry about? I am after a 2 inch but these are the only kits I have found that lift front and rear the same height.
Old May 23, 2012 | 01:49 AM
keithsfd7's Avatar
You stated that you are putting new shocks so they will be fine as long as they are meant for a 1.75 lift. You may want to put relocation brackets for your rear brake lines but other than that you will be fine.
