Offroading and Alignments... how often are you having to realign?
Old Sep 26, 2012 | 09:41 AM
Skumbag's Avatar
Default Offroading and Alignments... how often are you having to realign?
I got my alignment done and the jeep ran straight as an arrow. Steering wheel straight as well. I took it offroad over the weekend and noticed on the way back that its pulling to the right now. I'm also getting a pretty bad vibration around 40-45 mph. Perhaps a wheel weight fell off, I'm not sure. I'm just wondering how often you guys get your alignment done. Seems like such a waste of money if after every time you take it out, you'll need to get a realignment. Is there anything I can check myself? I'm pretty much a noob at the whole alignment adjustments, but if I can, I'd like to learn and figure out how to straighten it myself rather than blowing the $90 at a shop.
Any advice?
Old Sep 26, 2012 | 09:43 AM
Skumbag's Avatar
Mods:
37" Toyos
Rock Krawler stock mod 2.5" lift
Old Sep 26, 2012 | 09:48 AM
JKingAround's Avatar
You lost a weight on one of your tires
Old Sep 26, 2012 | 09:50 AM
Skumbag's Avatar
Checked psi and all at 28
EDIT: my bad i didn't read that right. Yeah I think its a wheel weight, but I didn't think it would make the vehicle wander to one side as much as it is. It could very well be though.
Old Sep 26, 2012 | 10:06 AM
c.boothe3993's Avatar
i need to know too. same thing happen to me without the vibration but my steering wheel is not strait after i hit the trail.
Old Sep 26, 2012 | 10:32 AM
Freewill's Avatar
Its all metal. Metal bends. The steering links and axle housing can bend with stock tires; they bend even easier with big tires.
Unless the 'C' or axle housing is bent, most off-road alignment problems are just the toe-in and steering wheel center adjustments. These can be set in the driveway, or even on the trail in a few minutes.
Lots of material here on the forum about setting toe-in and centering the wheel.
Old Sep 26, 2012 | 11:30 AM
D_engel's Avatar
I've never had the jeep fully out of alignment after wheeling, but I do usually have to recenter the steering wheel. It seems like you bent your tie rod
Old Sep 26, 2012 | 12:10 PM
suicideking's Avatar
Check your steering stabilizer, it may have been bent or broken and can cause the problems you describe.
It should be relocated. You can get a relocation bracket for around $35. A new stabilizer is around $75+.
I busted mine, bought a Bilstein stabilizer + relocation bracket. I also replaced my tie rod with a Synerg y because it was bent too.
Old Sep 26, 2012 | 01:28 PM
CerOf's Avatar
haven't done an alignment in 70,000+ miles.
That has included "bumping" my rig up and over a few things, a few stucks on logs, mud, small hills.
I try to be gentle though...daily driver....
Old Sep 26, 2012 | 02:22 PM
Rob 12B1P's Avatar
Sounds like you bumped your tie rod and lost a wheel weight. I just bungee two straight edges to the outside of the front tires and measure with a tape measure to set my tow. Its not super precise but seems to work well enough. I whacked the tie rod twice this summer and had to adjust it.
Rob
