Offset in Synergy adjustable front lower control arms ?
Old Aug 29, 2015 | 06:01 AM
rsmwrangler's Avatar
Default Offset in Synergy adjustable front lower control arms ?
i got those installed with the offset towards the outside, but now that i'm thinking about it, i should have asked to put that offset towards the inside, the damn instructions didn't say anything about the offset orientation, and my shop is not exactly an offroad shop, so they just followed my instructions :(
Should i go back and ask to switch them ?
20150824_135901 by SilverFJ RSM, on Flickr
20150824_135924 by SilverFJ RSM, on Flickr
Old Aug 29, 2015 | 06:09 AM
Albino Lizard's Avatar
Get a wrench. The Adjustable JJshould be on the axle side.
Old Aug 29, 2015 | 06:13 AM
Biginboca's Avatar
This is incorrect per synergy instructions. And yes the bend should be inwards not outwards, it helps with tire clearance when turning.
Old Aug 29, 2015 | 06:36 AM
I love how every manufacturer is different.
Old Aug 29, 2015 | 06:56 AM
TURTLECON's Avatar
Where exactly in the instructions does it say that? I'd love to see it, cause this setup looks wrong based on almost every other manufacturer's arms.
I'd still flip them around with the JJ on axle side and bend inward. Arms are arms are arms. There's nothing revolutionary happening with this set so I'd suggest to run it the same way almost all of them are designed to be run.
Old Aug 29, 2015 | 07:56 AM
Originally Posted by JK-FREAK
Where exactly in the instructions does it say that? I'd love to see it, cause this setup looks wrong based on almost every other manufacturer's arms. I'd still flip them around with the JJ on axle side and bend inward. Arms are arms are arms. There's nothing revolutionary happening with this set so I'd suggest to run it the same way almost all of them are designed to be run.
I agree. Tucking the adjustable arm up makes it real hard to adjust. Just saying.
Old Aug 29, 2015 | 09:55 AM
Phaeton's Avatar
Switch them around or your tires will rub them. Ask me how I know lol
Old Aug 29, 2015 | 11:08 AM
Biginboca's Avatar
It says it in step 4 of the install directions. Feel free to google and read for yourself.
Old Aug 29, 2015 | 11:21 AM
And that's exactly how i indicated my shop to go ahead and install them, however there is nothing about orientation of the LCA bent portion, if it wasn't because of the light rub mark i have in both of them, i would've never realized the offset should be pointing inwards, damn it, and it's rubbing lightly with 33's
"4. Install the new control arms with the bushing at the axle end and the flex joint at the frame end. Position the arm with the pinch bolt and the grease zerk in the flex joint on the top of the control arm. Reuse the factory mounting bolts. We recommend installing the axle end control arm bolts from the inside so there is minimal rock damage to the exposed thread on the end of the bolt"
http://www.synergymfg.com/instructio...L_ARM_V1_1.pdf
Old Aug 30, 2015 | 07:01 AM
TheDirtman's Avatar
Makes sense, you have the new Duro joints right? Putting the JJ at the top with the adjuster protects it and the grease zerk. Vibration reduction is there no matter what side the JJ is on.
