Oil change question
Old Jan 12, 2012 | 08:56 AM
Abritinboston's Avatar
Default Oil change question
K, this is a really db newbie question. I changed my oil this last weekend while I was putting on my ace sliders and OME HD lift (pics to come later), and every time I turn the jeep on, I still get the change oil message. What am I missing here?
Old Jan 12, 2012 | 08:58 AM
rinkishJK's Avatar
With the key on engine off push the gas pedal three times. Then turn key off and then back on. Light re set.
FoxRacingJMC's Avatar
All you need to do is turn your key to the ON position without starting your engine and then push your accelerator pedal to the floor 3 times. Turn your key off and you should be good to go.
Old Jan 12, 2012 | 09:00 AM
Pushrod's Avatar
Read your owners manual where it tells you to stick out your tongue, wiggle your ears and turn the key to the on position without starting withing 10 seconds and it will stop that. If you don't have the owners manual you can download one free from Jeep.com
Old Jan 12, 2012 | 09:01 AM
Wow, that easy huh ?
Old Jan 12, 2012 | 09:02 AM
Thanks guys!!! That is why I love this forum
Old Jan 12, 2012 | 09:12 AM
Pushrod's Avatar
Default The real answer.
Ok, I had to go look it up since I put the wise crack on here. So here it is from the manual.
1. Turn the ignition switch to the ON position (Do not
start the engine).
2. Fully depress the accelerator pedal slowly three
times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary repeat this procedure.
Seriously, if you don't have the manual you can find it on the Jeep website as a free download.
Old Jan 12, 2012 | 10:56 AM
Can we repeat this again for anyone who does not understand english?
Old Jan 12, 2012 | 11:31 AM
Pushrod's Avatar
Lots of willing help, 3 replies in as many minutes and no one knew the other was posting.
Old Jan 12, 2012 | 12:00 PM
Raider - I just busted out laughing at work....too friggin' funny.... GIT-R-DONE!
