Oil filter alternatives
Old May 23, 2008 | 07:48 AM
  #21
SteelMastiff's Avatar
Mind if I ask what filter you switched to?
Old May 23, 2008 | 07:58 AM
  #22
ursandal's Avatar
Just to pile on to the Mobil one filter bashing....I put one on my old YJ and it increased my oil pressure by 15psi (hot & cold). No other changes, same brand/weight of oil. I already had good oil pressure so I took it off and my pressure went back to "normal". I use Puralator PureOne filters now with Mobil One oil & have no complaints.
Old May 23, 2008 | 09:34 AM
  #23
Jusaplaya's Avatar
Same here guys. Mobile 1 oil filter and Mobile 1 0W-20 is what I was running. Engine made a knocking sound on startup kinda like when you crank the motor right after an oil change. I changed to fram extended guard and added a little more 0w-20 for what I lost and the noise went away. I wouldn't run a mobile 1 oil filter ever again. I'll probably go back to 5w-20 after 3,000 miles. I had that garbage on my truck for about half a day.
Old May 23, 2008 | 01:11 PM
  #24
Blue's Avatar
I run only Motorcraft, Mopar or Purolator filters. The high in Frams are good but the whored out their name at some point.
Old May 28, 2008 | 07:48 AM
  #25
Well I changed my oil this weekend and went with a AC Delco PF53 filter and it was cold this morning when I left work and low and behold I still had the knock.... Time to swap it out for one that others have had success with.
Old May 28, 2008 | 08:05 AM
  #26
Chukronos's Avatar
I switched out the mobile1 filter for the motorcraft FL-400S and the knock is gone. My knock wasn't too bad, but I was worried about it anyway. Now, no more knock.
Old May 28, 2008 | 08:18 AM
  #27
Wings fan's Avatar
Great topic guys. I switched over to Mobile 1 5w30 and a Mobile 1 filter and have had the same clater on startup. I thought it was the 5w30 vs 5w20. I will pick up a Motorcraft FL-400s on the way home tonight.
Old May 28, 2008 | 08:30 AM
  #28
Sounds like the Mopar or Motorcraft is a safe bet... I will be changing it within the next couple of days...
Old May 28, 2008 | 05:53 PM
  #29
Wings fan's Avatar
OK picked up the Motorcraft FL-400s filter and clater is gone! great advice. I also talked to the Autozone guy and he confirmed the same thing Modile 1 filters do not have the valve that retains the oil pressure for start up.
So the 3.99 filter is better than the 10.99 Modile 1
Old May 29, 2008 | 03:05 AM
  #30
pearl-drum-man's Avatar
I switched to Mobile 1 and their filter a couple weeks ago and immediately noticed the clatter after the Jeep sits. This weekend I am going to buy a Mopar filter and replace the Mobile 1 filter and see what happens.
