oil filter fram PH3600
Old Sep 20, 2008 | 09:08 AM
hardcoreoffroad's Avatar
Default oil filter fram PH3600
Biger than stock, more oil, more filter media, beter for your jeep PH3600 FRAM oil filter. JUST BE SHURE TO PREE FILL YOUR FILTER BEFORE YOU INSTALL IT!! You will need jus a bit more oil to add to your oil pan becouse of the filter holds more oil
I was at the dealership and seen some longer filters and asked and they said it would work for the JK. The filter is origanaly for the PT cruiser one is for the turbo and the other is for the nonturbo short and long filter . The short filter is also the factory JK filter. The long filter works on the Jk Wrangler witch is good becouse bigger is better ,more oil capacity,more filter capicity,more cooling serface on the filter. I went to autozone and had the PT Cruiser filter cross referanced and it is a PH 3600.
Old Sep 20, 2008 | 09:11 AM
Robar's Avatar
Default Oversize oil filters
--------2007 Jeep JK--------
----Make------Stock------Oversize
Amsoil--------EAO57------EAO34
Fram---------PH3614-----PH3600
K&N---------HP-1002-----HP-2009
Mobil--------M1-102------M1-209
Mopar--------L-335----------???
Napa----------1348---------1516
PureOne----PL10241----PL20195
Purolator----L10241------L20195
Wix------------51348-------51516
Old Sep 20, 2008 | 10:34 AM
Dubya's Avatar
Talking
Wow Robar, 3 minute response time
Anyhoo, I have been using the Mobil One M1-209. Are all those in the right column of your list the same size as that?
Old Sep 20, 2008 | 11:21 AM
Robar's Avatar
I have had that info for over a year or so.
I am not sure of the exact capacity, but they are the equivalent fit, oversize filter, for each brand.
Old Sep 21, 2008 | 07:25 PM
afoulk's Avatar
I have the Fram TG3600 and found that it really didn't add that much more oil capacity to my engine. Nothing that would have benefitted it at all anyways. How are you guys pre-filling the filter before putting it on since it mounts horizontally?
Old Sep 23, 2008 | 11:14 AM
unlimitedone's Avatar
I had the same question.
...plus, why would you need to pre-fill it, if the system will pressurize and fill the filter within seconds of start-up...?
Old Sep 23, 2008 | 12:10 PM
fiasko915's Avatar
may be a stupid question, but what benefits does the oversize filter have vs the regular size?
Old Sep 23, 2008 | 01:36 PM
JdTms11's Avatar
as a rule of thumb my auto teacher in HS always told us to put a little oil into the filter. i think it had to do with making up for the loss of filtered oil from when you remove the old filter, with oil in the filter it immediately goes back into the engine, rather than having to wait for oil to come in go through the filter and then back in. im sure it doesn't matter that much, like you said the oil is pressurized instantaneously anyway. i dunno just habit now i guess
Old Sep 23, 2008 | 02:24 PM
muddpuppy01's Avatar
I would guess its was a old thing to do with oil preassure not being as high as new motor have they and it also reminded people to lube the o ring on the filter
Old Sep 23, 2008 | 03:35 PM
ahh.. good answers!
