oil help
Old Apr 25, 2008 | 07:12 AM
jeep07's Avatar
Default oil help
i have a 07jeep and have not changed the oil yet. When should I do this and how often should I change it? What's a good oil?
Old Apr 25, 2008 | 07:16 AM
pearl-drum-man's Avatar
Everybody seems to have their own opinion on this. IMO, you can't go wrong with following the factory specs in your owner's manual. If you do a search you'll get hundreds of posts on this topic which will give you a great overall view about it.
Old Apr 25, 2008 | 08:12 AM
H2_RESQ's Avatar
I changed at 1500 and will do it again at 3000, and then every 3000 thereafter. I use Ford/Motorcraft 5w20 semi-synthetic.
Old Apr 25, 2008 | 11:23 AM
08JKWrangler's Avatar
This might actually be a good survey to post.
Do you
(1) Change your oil yourself;
(2) have the Jeep Dealer change the oil;
(3) use Jiffy Lube or a similar type fast food oil shop?
Old Apr 25, 2008 | 11:31 AM
Do you
I got 8 free oil changes from the dealer, so I've been letting them do it thus far, I will take over when those are done. I will never trust my vehicles to the quick lube shops, too many horror stories about those places.
Old Apr 27, 2008 | 05:00 PM
Bump! Bump!
Old Apr 27, 2008 | 05:31 PM
BaltChief's Avatar
Many years ago I used to use Jiffy Lube....One time they put my drain plug in hand tight and I wrote it off as a freak thing. Not too long after that they replaced my oil filter and didn't remove the old gasket....NEVER again will my tires see thier lot.
