OME 2" lift
If it feels a bit skittish to you a set of adjustable front lowers would probably be enough to fix it (leaving the other 6 arms alone).
I have the OME on a 4d Rubicon. I have the stock arms and the stock track bar and love it. It's about 95% of stock as far as steering and driving. If you go over 3", it's a little flighty on the highway. If you go with HD springs with no bumper/winch, you will get 3-3.5" of lift. Mine settled to about 2.25 to 2.5 with the winch and now it feels like stock again.
The key is set up your Jeep so you are sitting at the 2-2.5" mark. If you go HD on the springs but don't have the weight to push it down, your lift will be much more than 2".
Just the lift: http://www.northridge4x4.com/proddet...rod=OME-JK-2HD
The lift with adjustable track bars: http://www.northridge4x4.com/proddet...rod=PKG-OME-JK
