OME 2'' or TF 2.5''??
I've been debating these two choices for quite some time now. Did tons of research on both kits, contacted manufacturers, compared them with other kits and finally narrowed it down to the OME kit. I have an 08 Unlimted Sahara which is a daily driver and want the better than stock ride (the roads here in this city are bumpier than a country road) and I don't think I'm ever gonna go larger than 33's. My plan was to go with the OME with standard coils that way I'd only get the 2 - 2.5" of lift that I want. I too wonder if this kit will reduce that front rake or whether I'll need the small spacers that the write-ups show using.
My only question is that I still am confused why the TF kit, basically nets the same height as the OME kit, yet the TF kit comes with the extended bump stops, rear links, and a trackbar relocation bracket. The OME kit doesn't come with these which makes me wonder why. I guess the TF kit is just a more complete kit than the OME kit and these "nice to haves" come standard with the TF kit. When you start adding on these nice to haves to the OME kit, you're really adding on an extra few hundred bucks. But I guess that's what happens when you own a Jeep!!!
Regardless, I reused the stuff from my TF BB, and then added new trackbars and control arms. It's a great kit overall, even given the cost. (Buy it from Dave at Northridge too... it'll end up being a little cheaper, and the customer service is truly outstanding!!!!)
I ended up getting the OME with the standard springs... I don't see myself getting tires any larger than 33" (due to 3.21 gearing), so the extra lift wasn't needed.
She drives MUCH better than before. I will say, though, you'll be spending a few hundred more bucks on the OME setup than you would with the TF 2.5" coil kit.
But, I would say if you have the $$, spring for the OME.
With that said, I was still able to save money starting out with the TF BB, but IMHO the OME coils are sweet and they cost less, which is a plus!! They just about level er out with no problems.
My apologies for not adding pics, I'll be sure to add them soon for all of you scratching your head out there.
Not to be rude, but use the SEARCH feature. This is a very common topic.
BTW, I've helped you out...... see the following threads
https://www.jk-forum.com/forums/show...&highlight=OME
https://www.jk-forum.com/forums/show...t=OME+Teraflex
how much better was the ride? what kit do you have and what springs did the guy with the ome have? standard, md, hd?
As far as ride quality goes I have found that the AEV kit has the smoothest ride out of any suspension I have ridden in so far. Part of it is the stock arms with bushings that help to control the transmission of some of the vibrations, and part of it is the springs being progressive. Also the handling was much more precise feeling than mine (which is sad to say since it had 35" tires on a 16" wheel compared to my stock Rubi wheels) because of the drag link flip.
