OME & extended bump stops?
Old Mar 30, 2008 | 07:11 PM
adaycj's Avatar
Originally Posted by Robar
Let me say this, it is my understanding that ARB designed the OME shocks to work as limiting straps to prevent damage to the brake lines or the springs just falling out during a flex. However I am planning to extend my brake line bracket down, because at full flex the brake lines do get tight. It is also my understanding that the OME coils are designed not to over compress eliminating a need (IMO) for bump stops. I have had limited chances to work out my suspension since I got the KM2s, but I have had it at full flex, with front sway bar disconnected, and did not notice any rubbing. I will also add, that my wheels have 5" of backspacing which is about 1 1/2" less than the stock wheels.
I am very happy with the performance and ride of the OME lift that I have. I would also recommend front and rear adjustable track bars to recenter the axles after the lift.
Thanks for clarifiying Robar. I have not seen or measured the stacked height of a OME spring to see if it does indeed limit upward travel. If it does limit upward travel then it is possible that an additional bump stop extension (or replacement) is not needed. If indeed the springs do this, then the picture I posted may not apply.
Thank you Robar for not taking offence to my post. I'll give myself a for not thinking of the spring limiting upward travel.
Anyone got a picture of a fullly stuffed OME spring they can share? It would add to the thread.
