Ome Hd Suggestion
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
The rears you can slap on any time. Quick and easy two bolt install. I suggested the fronts simply because they go inside the coils.
OME HD - No bumpstop (I've read this is kinda bad...)
![](http://my.project-jk.com/data/500/medium/JK_0052.jpg)
OME HD - With bumptop
![](http://my.project-jk.com/data/500/medium/W-Bumpstops_009.jpg)
Anyway, for me, bumpstops are definitely 'needed'. Even with the bumpstops, I still rub my 34's on the upper fenders.
Will you need them? Only you can decide that. But it's a lot better to have them and not need them, than to need them and have to rip the front end apart a second time to install. (the pics show just how I know that...)
so are they even needed?
I have 2" Rubicon Express lowers up front, and 2" TeraFlex lowers in back.
With spring spacers, I have a total of 4" of lift up front. As I mentioned above, even with the 2" ext bumpstop, I still rub my 34's on the upper fender. (I'll get around to trimming the fenders rather than add more bumpstop)
But that is disconnected. If you will not be disconnecting, you may not need them at all. (I haven't flexed while connected to check it, so can't answer that)
1 Post
For the OME Kit, I got the fairly basic one from Northridge. (ie the OME springs (HD), shocks + adjustable track bars.) I also added Currie endlinks so that the swaybars would be at the right angle. I eventually had to add SpiderTraxx spacers (because the Currie endlink on the passenger rer tire was rubbing against the wheel.) Here's the link on my install:
https://www.jk-forum.com/forums/modified-jk-tech-2/ome-install-progress-thoughts-pics-included-74110/
This is really about all you need in most circumstances. I run 90% street and the ride is supurb. Last week I went to Morris Mountain ORV in Alabama. The trail was gnarly. Full flex, stupid steep hills, trees, boulders, etc. Never had probs with the OME kit. The brake lines were fine and the Jeep stayed controlled on terrain that probably would have resulted in a flop on a stock Rubi suspension.
So, in short the OME kit + trackbars + endlinks + spacers are fine. The other stuff is nice, but Ive found it unnecessary
Think the totalt bill for all above was around $1100.
BTW, I got 3 5/8" lift from my OME "2-inch" HD kit. That's AFTER settling.
https://www.jk-forum.com/forums/showthread.php?t=74110
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
Be sure to flex and check before you get out in the boonies...
