OME Lift question
Old Jun 4, 2008 | 04:11 PM
envied4x4's Avatar
Default OME Lift question
I just installed the OME 3'' lift on my 2dr 08 Rubicon. But the problem is that when i take it off road it makes all sorts of noise. I cant find where the noise is coming from if anyone has installed this lift and might know what the problem is. Please let me know.
Thanks
Old Jun 4, 2008 | 04:26 PM
envied4x4's Avatar
no it didn't
Old Jun 4, 2008 | 04:34 PM
seer1's Avatar
Have the arms and trakbars all re-torqued.
Old Jun 4, 2008 | 05:37 PM
envied4x4's Avatar
What should the arms and track bar be torqued at
Old Jun 4, 2008 | 06:53 PM
nukeman's Avatar
You did replace/re-install the spring isolators when you installed the new springs right?
First, check everything you touched. Then get underneath it and push up and pull down on the frame as much as you can to try and find where the noise is coming from. Sounds like a track bar issue, but could be anything from spring isolators to sway bar links.
Old Jun 4, 2008 | 07:01 PM
envied4x4's Avatar
When i got the lift all the sent me was new springs, small spring spacer for the front, shocks, and sway bar links. Should i have got more for $900
Old Jun 4, 2008 | 07:04 PM
Robar's Avatar
My OME does not make any noise. Are your shocks tight enough and what kind of sway bar links did it come with?
Old Jun 4, 2008 | 07:09 PM
envied4x4's Avatar
It just came with longer rear links and then i put the stock rear on the front. and you say check the shocks to see if they are tight enough?
Old Jun 4, 2008 | 07:11 PM
Robar's Avatar
First check to make sure the sway bar links are tight. Then check the tops of your front shocks to make sure they are snug and not moving around.
Old Jun 4, 2008 | 07:29 PM
envied4x4's Avatar
It seems like it does it more when i have the sway disconnected but it sounds like it is coming from the rear.
