ome light load 3" kit
Old Apr 25, 2012 | 03:48 PM
nvrtoomanytoys's Avatar
Default ome light load 3" kit
anyone running the light load springs and shocks? ive got a "custom kit" planned out so see if ive done anything wrong here.
ome 3" light load springs and shocks
currie front lcas
jks adjustable front trac bar
no bump stops
planning on running a 35x12.50 on aftermarket wheels and havent decided on them yet. gonna have to keep my stock wheels and 295s for now. also will i have any ds issues with the 3 inch kit? found a good deal on this stuff at 4wd. let me know if im missing anything. thanks in advance.
Old Apr 25, 2012 | 04:21 PM
no help? not trying to rush but if everthing looks good i might get to order this tonight.
Old Apr 25, 2012 | 04:32 PM
Bowman's Avatar
1) You won't get 3" of lift with the light springs
2) If you dont plan on going over 3" of lift, you do not need LCA's
3) You might want to consider getting a rear adjustable track bar as well
Do you plan on running the regular shocks or the long travels?
Old Apr 25, 2012 | 04:36 PM
if not 3" then how much do you think ill get
without the front lca's how can i readjust my caster
why the track bar and not the relocation bracket
the shocks that would be run are the shocks that come with the 3" kit at 4wd.com
only reason i was going with the light load springs was to keep my ride nice and plush.
Old Apr 25, 2012 | 04:40 PM
Atch's Avatar
With the light load u will sag if u add much weight, my hd rides nice, not rough at all
Old Apr 25, 2012 | 04:42 PM
Bowman's Avatar
The height will depend on if you have a 2 door or 4 door. If a 2 door, I would guess 2.5" and a 4 door would be less than 2. I have a 4 door with med duty coils and it netted around 2.5".
Your lift isn't high enough to worry about your castor.
The relocation bracket is just a weak spot in my opinion. You have much more flexibility by using the adjustable bar and can center your rear better.
Old Apr 25, 2012 | 04:52 PM
after looking at 4wd site again i have also looked at the full traction 2" kit. i dont offroad a lot and this jeep is my dd and it rides really good now so im wanting to keep my ride as close to stock as possible. i also want to get a "plug and play" setup that i can install and drive and not have to worry about "tweaking this and adjusting that". i also would like to keep any adjustments and angles as close to stock as possible without breaking the bank if thats even possible to do.
Old Apr 25, 2012 | 05:28 PM
Mr.T's Avatar
Community Favorite
Mine has the light springs on a two-door. It was about 2.5+ inches of lift. Added a winch and bumpers, it's still sits 2+ inches over stock. If it's the same OME kit with shocks I installed, the shocks have 1" more travel then stock, and I did not use any bump-stop extensions to reduce travel. At 1" longer travel, the original driveshafts are OK. Check your rear brake lines at full extension, and slightly bend the hard lines at the wheel end for just a little slack in the flex lines if necessary. Also, the axle vent and electric locker wiring will need a slight adjustment to where they are ty-wrapped with the extra inch of travel. I did not adjust the caster, and used the stock control arms. My functional test for caster is to drive a straight flat road, let go of the wheel and see how it drifts. Did a before and after test, mine handles almost exactly the same on the road as before the lift. I'm very satisfied with it. It's a nice amount of lift with minimal change to the suspension geometry and stress on other parts.
Suggest downloading the instructions for the Mopar 2" lift (or similar) and the OME write-up from Project JK -- The OME kit doesn't come with instructions.
Old Apr 25, 2012 | 06:53 PM
blackpanther's Avatar
I have the light load with the nitrocharger sport shocks,on a 4 door.
It gave me 2" in front and 2.25" at the rear.
With the soft top on the rear raises yet another .5"
I will be adding 1/2" spacers up front.
And like another poster said if you do add bumpers etc.....it will sag.
They are a softer coil which is what I wanted.
The ride is alot better and softer than stock.
If I were to add bumpers and acessories I would get the medium duty.
