OME question
Old Jan 29, 2008 | 11:47 AM
monte's Avatar
Default OME question
After installing the 2" OME lift (or any lift for that matter) I find I need a little more height or need to level out the rake, can I add spacers on top of what's been installed? Or do I need to uninstall the OME and go with a bigger lift kit?
Old Jan 29, 2008 | 11:51 AM
Default you sure can
yeah, you can put spacers on top of the new coil springs after you have lifted it. i would keep it to a 3/4 or 1 inch spacer though so you dont have to get a new trac bar, brake lines, or longer shocks.
Old Jan 29, 2008 | 11:53 AM
Northridge4x4's Avatar
Sponsoring Vendor
Yes you can also just so you know the OME kit comes with 3/8 spacers for the front.
David
monte's Avatar
Thanks. Would I be able to put the new spacer on top of the existing OME spacer, or should I have only one larger spacer in place?
Old Jan 29, 2008 | 12:49 PM
Sponsoring Vendor
I would prefer 1 spacer.
