Which OME shock will fit?
Old Jan 24, 2008 | 12:10 PM
yoshillopez's Avatar
Default Which OME shock will fit?
If I install a 1.75" coil spacer in the front and a 1" coil spacer in the rear of a 2 DR X, which Old Man Emu shock can I fit? There is one dedicated for the JK, but on Qudratech's website, it is listed as a 2" lift front shock. Would I be able to use this on front and rear with the above setup? What other parts or modifications would I need?
Old Jan 24, 2008 | 12:52 PM
Northridge4x4's Avatar
Sponsoring Vendor
We have these in stock and yes they will work.
http://www.northridge4x4.com/proddet...rod=OME-SHOCKS
We are updating the drop down menu to add JK into that.
David
