Ome steering stabalizer for aev lift
Old Apr 15, 2013 | 06:34 PM
jeepwave's Avatar
Default Ome steering stabalizer for aev lift
As a lot of you I have had the dreadful pull to the left with my billstein stabalizer from my aev lift
I have the ome one in my garage but haven't changed it because I wanted to "just get use to the pull" but now it's pissing me off!
My question is for those of you with an ome stabalizer, any problems? Any shimmy? Any dw?
Thanks
Old Apr 15, 2013 | 06:46 PM
Irish Bullfrog's Avatar
Although the SS will help, it will not fix... I would recommend have a shop check the alignment and steering geometry...
Bullfrog
Old Apr 15, 2013 | 07:29 PM
Ncb's Avatar
Ncb
I've heard of the Bilstein SS causing a pull. I have the OME and it's all good. No pull.
Old Apr 16, 2013 | 01:00 AM
JK Inspired's Avatar
Bilstein- gas pressurized
Old Apr 16, 2013 | 01:26 AM
Kojack's Avatar
The ome will fix it.
Old Apr 16, 2013 | 01:44 AM
Mello03's Avatar
How much pressure comes in the Bilstein stabilizer? I have ran them in the past. Many guys that run these on their full size dodges have to adjust the pressure to compensate for the pull. I know some different manufacturers ship them with different pressures for different applications. It may be worth finding out how much pressure is in it and letting some out if it's pushing your truck. That's what I would do before I bought a new set up. A lot of motorcycle places can pressurize the nitrogen in them. Beware if you let any gas out of it, it will come out quick though.
Old Apr 16, 2013 | 01:53 AM
Alpine6's Avatar
I have the OME and was concerned about the pull just from reading others issues with the Bilstein ones. Fortunately there's no issue with my OME. Would recommend!
Old Apr 16, 2013 | 06:16 AM
jeepwave's Avatar
Thanks. I already read a bunch of threads saying it will fix the pull
I was more concerned with the new ome stabalizer causing a shimmy. But of you're saying the ome has worked nicely for you then I'm sure it will for me too
