onboard air system
Old Oct 27, 2008 | 09:27 AM
overkilljk's Avatar
Default onboard air system
look at Viair system. think of going with 450c (100% duty) pump, 2.5 gl tank ete. look for air supply that can be anytime, run air tool on the trail and fill tire fast
? 1 who have this setup, how do you like it
? 2 is a less $$$ way to go
Old Oct 27, 2008 | 10:01 AM
bly109's Avatar
I have the 450C and I love it for airing up tires. It will just keep going and going.
It would not do a very good job of running airtools. Maybe with a bigger tank, but I doubt it. I think Viair reccommends using twin 450C's to run airtools
Old Oct 27, 2008 | 10:17 AM
Choppus's Avatar
Is there an onboard air system on the market that is 100% duty cycle that will run air tools?
Old Oct 27, 2008 | 10:20 AM
bly109's Avatar
The only ones I have seen are the Viair twin 450C setup or a York belt drive setup like the one River Raider makes.
Old Oct 27, 2008 | 11:05 AM
Choppus's Avatar
thanks for the quick response.
Old Oct 27, 2008 | 11:08 AM
bly109's Avatar
I think you can run airtools with a CO2 powertank too
Old Oct 27, 2008 | 01:25 PM
overkilljk's Avatar
-- on belt drive setup and co2--
belt drive setup/ you lost a belt, pump or election ck fales on you you r w/o air and your jeep in mid nowhere. I know of time this have happer. in the mid-Frebar in West Branch Mi. if rand mazgch of snoblind it a good time
co2 out co2 out of air if you going WITHOUT refueling your tank after us
Old Oct 27, 2008 | 05:02 PM
Littlejon's Avatar
I would think if you lost a belt you would have bigger issues than your OBA since you wouldn't have any accesories running. As far as an electrical connections failing on a belt drive I would think there would be less chance than with an electric compressor since there is a lot less electronics involved, otherwise any electrical connection has an equal chance of failing if they are off done exactly the same.
Old Oct 27, 2008 | 06:49 PM
Strong Bad's Avatar
I have the Viair 450c and love it. I haven't tried to use it with air tools, so I am no help there.
Old Oct 27, 2008 | 07:28 PM
castor07jk's Avatar
where dd you mount the comp?
