Open carrier for Dana 44 front?
Old Feb 24, 2022 | 11:36 PM
Veritass's Avatar
Default Open carrier for Dana 44 front?
Either I have over looked this and unable to have found a form with the answer or its such a bizarre question it has yet to be asked. If some one knows the answer and could point me in the right direction, it would be very much appreciated.
I am in search of either a open carrier, posi, limited slip or something other than a locker that will fit into a Dana 44 Front axle for a JK 2014.
To be exact it would be fitting this housing G2 Axle & Gear Part #: 67-2051JKFL.
Old Feb 28, 2022 | 11:27 AM
Digger 5's Avatar
That part number says it's a metric housing that is designed for the factory JK electric locker. Due to the offset cross pin tin the locker, no standard diff will fit using the electric locker axle shafts. It also uses a different size carrier bearing which prevents a standard open diff from fitting.
