optima question
i happend to have two brand new blue tops land in my lap and was wondering would they work for my jeep. i realize they are for marine use but what is the difference. marine engines are the same as car engines!!!
thanks
thanks
They'd work...but they trade raw cranking power for deep cycle endurance...IE: Long distance runner vs sprinter in output.
Plenty of people do this, and if the cranking specs are sufficient to turn you over when needed, you're good to go.
I am running a Optima Blue top because I am running (6) SolTek lights and a Warn 9.5Ti winch so I wanted the "staying power". The battery has been great so far and I couldn't be happier. Also with the blue top's you get an extra set of terminals for your aftermarket add on's. You'll really like it.
Good luck, Ben
Good luck, Ben
Which Blue-top model? I just purchased a D34M which is identical to the Yellow-top D34/78 except for the location of the auxilliary posts (top on the Blue, side on the Yellow).
on your lap that must have hurt
