Ordered rubicon express 2.5 inch coil lift, questions.
Old Apr 10, 2013 | 08:41 AM
jkfsu's Avatar
Default Ordered rubicon express 2.5 inch coil lift, questions.
Ordered the 2.5 inch rubicon express coil lift to replace my RC 2.5 inch budget boost. Anyone have pictures of this kit on their jeep? Should I not use the included cam bolts? Any negative reviews about this coil lift? Will the springs sag with added weight such as bumpers or spare tire?
Old Apr 10, 2013 | 08:46 AM
Quentin_T's Avatar
In order to use cam bolts you have to wallow out your LCA axle mounts, something I would never, ever do. Plenty of people have done it successfully but mine are so beat on (mostly passenger) I would be afraid to loose any more metal.
Old Apr 10, 2013 | 08:54 AM
glock35's Avatar
I have had that kit on for a couple weeks now. Rides really nice. I have a winch and aftermarket front bumper and the front is a tad bit lower than the rear. I expect it to be level with an aftermarket rear bumper. I replaced a Tereflex leveling kit and gained just over an inch all the way around over the leveling kit.
Old Apr 10, 2013 | 11:54 AM
jkfsu's Avatar
so should i skip using the cam bolts? my jeep has been driving just fine with the Rough country 2.5 inch budget boost.
Old Apr 10, 2013 | 01:44 PM
malignant's Avatar
I have the 3.5" kit and instead of using cam bolts I put in the AEV Drop Brackets...works fine for me.
Old Apr 10, 2013 | 01:56 PM
Jeepnut67's Avatar
Post I posted about this kit recently.....
I had the same concern about the cam bolts I'll probably not use them
Old Apr 11, 2013 | 06:06 AM
jkfsu's Avatar
same, ill probably just scrap the cam bolts/washer. Last question!!!! How do these coil springs hold up to spring sag/weight?? anyone have some ideas?
