Over active ESP
Recently the addition of my JKS quicker disconnects and re-connection of my rear sway-bar have increased the ESP response. I am not sure if it is the disconnects causing it, but it appeared around the same time of the install. I have checked to see if sway bars are in the correct position and equal. Tires are inflated so no cause there. I checked the lower control arms and they are good still @ 23" and tight. Axles are centered all tight and adjusted. If anyone else has experience identifying causes for the stupid ESP please help a brother out..
Originally Posted by Tonka_yellow
If you can adjust them, tighten them up a bit. If they are loser then stock the esp will go off a lot quick due to the front rolling to a side easier
Yes steering wheel is straight. Everything is torqued to 125 lbs/ft. No concerns there. Dropped lower control arms tonight they looked good. Did a visual on uppers look good. Tire pressure is at 32f and 30r.
I'm starting to think its the links.
A little play, but not enough in my opinion to impact anything. I am ready to replace them but I dont feel at this time its ready. I double checked them last night after you posted. While there I did check the connects, it appears that they move on the pins significantly. I may be reaching out to Northridge just to pick their brains and JKS. All is still pointing to the connects. Even though there should be minimal side load on them.
