Over compressing springs
Old Jul 5, 2012 | 09:03 PM
SBEII's Avatar
Default Over compressing springs
Is it possible to over compress your springs? I'm running a Teraflex performance leveling kit with 35x12.50s and it looks like the spring completely compresses. Any ideas?
Old Jul 5, 2012 | 09:04 PM
wayoflife's Avatar
JK-Forum Founder
absolutely. and, it is the primary reason why you need to install bump stop extensions with a lift. with just a leveling kit, i wouldn't think this would be a problem but, if your coils are going solid, that is not a good thing.
Old Jul 5, 2012 | 09:08 PM
SBEII's Avatar
There may be a hair in between them but they look pretty tight and I don't think it was flexed all the way. I had to stop and back down because the rear was rubbing my rail.
Old Jul 6, 2012 | 02:51 PM
Markdsv's Avatar
I had similar issues going on expedition with a loaded car. I am running TF bumpstops, really pleased with it as it prevents my springs from compressing too much. Also when I go over humps it catches my bumpstops so no bottoming out any more
Old Jul 6, 2012 | 04:57 PM
notsoricer's Avatar
cut about 2 inches from your rails with a saw-zaw and add bumpstops that re the same height as your lift. you can use hockey pucks if you want to save a few bucks.
Old Jul 6, 2012 | 05:15 PM
SBEII's Avatar
Thanks. The rails are on my to do list, it's just been sooo hot. I'd never thought about longer bump stops since it was only a leveling kit.
