Oversized Tire Carrier by Smittybilt
Has anybody used this? Would this be a cheap alternative to the more expensive tire carriers? It says it eliminates tailgate sag.
http://www.4wd.com/productdetails.as...5&partID=45001
It attaches to the factory holes, and still leaves all the weight on the factory hinges.
It'll probably let you fit whatever tire you want on there...but I'd wager that you'll still have exactly the same long-term problems with hinges and sheet metal as you would if you put a big tire on the factory carrier.
I thought the same thing ref the tailgate sag. It does say "adjustable arms" what Im thinking, is that you probably lengthen the arms to "rest" on whatever bumper you have.
I just think the advertisment wording needs to give a better description
Yes...but if it uses the original mounting holes, you may still have some sheet metal issues.
Ah I see what your saying. The downward pressure may be taken care of by the adj. arms, but the "outward" pressure would still be pulling on the tailgate.
Good point...
Bamn! Heavy duty bumper and tire carrier is still on the list.
Good point...
If the carrier mounts on the tailgate side of the hinges, the weight is still on the tailgate. What kinda design is it that the "arms" would rest on the bumper and scratch it all to hell? Sounds kinda stupid. A bigger picture might help. I can't see a damn thing.
