P0031 after replacing all 4 O2 sensors, EGR, plugs/wires/coil
Hey guys, first post. Sorry to ask for help before contributing anything, but I’m kind of lost. I replaced all four O2 sensors, EGR valve, plugs/wires/coil today on my wife’s 08 Unlimited Sahara to battle a plethora of codes, including multiple 02 sensor faults and a random misfire issue. Jeep runs amazingly well now, but I still have a P0031 code. I’ve looked pretty hard on google, YouTube, etc, but cannot find anything JK specific regarding a fix or troubleshooting procedure. I’d really appreciate any help y’all can give, I’m really struggling here. I’m back at it tomorrow doing ball joints and some other maintenance items so I’ll be able to run down any rabbit holes y’all can suggest. Thanks!
doug |
1/1 o2 sensor heater control circuit... Make sure you have no power to o2 sensor heater circuit with key off, if you do you will burn out o2 sensor. Basically you have a wiring issue from pcm to 1/1 o2 sensor (circuit k99 br/lg wire cavity 1) or you have a bad ground from o2 to ground (z906 black wire cavity 2).. Check for power with command heater on to k99, check ground at cavity 2... If this checks out you have a defect o2
Is it possible
Hi
I had all of these codes show up at on time: P0031 P0037 P0051 P0057 Could all four actually go out at the same time? I have a 2008 JK Sahara Thanks George |
Originally Posted by gfe jeep
(Post 4342355)
Hi
I had all of these codes show up at on time: P0031 P0037 P0051 P0057 Could all four actually go out at the same time? I have a 2008 JK Sahara Thanks George Possible Causes O2 SENSOR XY HEATER CONTROL CIRCUIT SHORTED TO GROUND O2 SENSOR PCM |
Thanks Mr T
Thanks for the information. This was my original issue then other codes and problems were found. I eliminated all except these four. I also read about 02 eliminators but would do that as a last resort. I think some of my problems were a caused by a spike in voltage from the alternator. I have determined the PCM is working, repaired some grounds (one was broken that went to the engine block). During this time I replaced the ERG, and spark plugs and wires. I have a Crankshaft Position sensor on order for rough idle. I'll check the wires that go into the )2 sensor plugs next.
I'll see if I can find hows this is operating! |
I’m having an O2 sensor issue. All 4 sensors read high. With the sensor disconnected I get a ground on all 4 wires going to the ECM. I disconnect the orange connector and the grounds go away. I read that an open would cause a high ckt indication. Does that mean I have an open between the connector and sensors? Would I get a high ckt indication if I left the 1-1 sensor disconnected? I have replaced the EGR valve, and PCM, I had an issue where the Jeep wouldn’t start but after running a ground wire from the battery to the engine ground it starts fine. What should I do now?
Originally Posted by Jim553
(Post 4347240)
Regarding what does an O2 sensor reading do with a disconnected sensor, I believe it will read high on a scan tool. Is this possibly related to replacing all the O2 sensors? What orange connector are you referring too, and which side of the connector is being tested? What method are you using to determine that all 4 wires from each O2 connector to the PCM are showing they are grounded? :beer: |
O2 sensor 1/1 schematic
Here's a schematic of O2 sensor 1/1 for reference, the others are similar - just different connectors/pins.
https://cimg4.ibsrv.net/gimg/www.jk-...0aa3cf25d8.jpg |
The sensors go through the two middle connectors on the PCM right? The orange connect is the second one counting from the drivers side of the vehicle. Back info I was not able to start the Jeep with out disconnecting and reconnecting the orange connector. I fixed this by running a ground from the battery to the engine ground. The sensors were working fine then 1-1 went high, replaced that twice, and a cracked exhaust manifold, Then 2-2 went high, a week went by and all sensors read high. I read the sensors and they all have 2 to 8 ohms across the heaters. When I read the wires going to the pcm all the wires had either .8 to 0 ohms to ground. I replaced the PCM. Same issue. I started getting misfires if 1-1 was connected. So 1-1 is now disconnected. I thought I had a ground issue but then read that you get a high indication if there is an open. I do not know what I should read went testing the PCM connectors. I figure I should try reading the PCM connector to the sensor connector however I’m not sure what pin goes to what. I don’t want to waste money on a harness if that’s not the issue.
I appreciate the schematic, I have a question. If I’m looking at this right the heater ckt and sensor ckt are separate right? If that’s the case then when they say that an open would give you a high indication are they talking about on the signal side or heater side?
