Sorry another question, the s133. What does that mean? Is that just a connection point or am I mistaken?
The pin and connector for 1/1 are in the scheme above (post 8). With 1/1 disconnected does it read high on a scan tool?
:cheers: |
Originally Posted by Jim553
(Post 4347249)
(Post 4347248)
I appreciate the schematic, I have a question. If I’m looking at this right the heater ckt and sensor ckt are separate right? If that’s the case then when they say that an open would give you a high indication are they talking about on the signal side or heater side?
P0131 O2 sensor circuit low When Monitored: Engine running for less than 30 seconds and the O2 Sensor Heater Temperature is less than 251 degrees C (484 degrees F) with battery voltage greater 10.4 volts. Set Condition: The oxygen sensor signal voltage is below 2.5196 volts for 6 seconds after starting engine. Two Trip Fault. Three good trips to turn off the MIL. |
Yes with 1-1 disconnected I still get a high with the scan tool. I do not know why when it is connected I get misfires. I going to find a schema for all 4 sensors, maybe there is a common connection point or route the harness takes that could of opened?
Mr. T I seem to of missed some of your questions. I’m using a fluke meter to take all my readings. I have a scan tool to read the fault codes and reset them. That’s about the extent of its capabilities. Would you know where I could get a full pin out for the second connector on the PCM?
I took reading on the C2 connector. Between c18 and C31 I had 0 ohms. Both C18 and C31 go to the same pin on the connector between the harness and sensor.
never experienced it. but this is a really very interesting discussionhttps://juragan.club/assets/8/o.png
(Post 4347265)
But here's where I'm confused, C2/18 goes to pin1 at the 1/1 O2 sensor connector (heater +) and C2/31 goes to pin 4 at the O2 sensor connector (O2 1/1 signal). With the sensor disconnected (or connected), the resistance should be infinity between these points regardless of whether measuring at C2 or the O2 sensor connector (and I'd do it both ways). If it's actually shorted, the wiring is bad -- very uncommon but possible if critters are munching on them. You could really benefit from getting some type of scan tool or software that can read values from the PCM. If you have a laptop, the Appcar DiagFCA software with an OBDLink MX+ bluetooth adapter (includes OBDwiz graphing software) is very capable. There's others too, I did a review in a recent post you can search for. Knowing how to use a meter is great, but often it takes knowing what the PCM is actually seeing, and starting there is a lot easier/faster. This only matters if you're doing key-on voltage measurements, but Chrysler/Jeep usually has a bias voltage on the O2 sensors. With a 2.5 volt bias -- Measure 3.0V with a meter and OBD2 software like HPTuners will show 0.5 for sensor volts from the PCM, but there could be a scanner tool or software that include the bias and display the raw 3.0V. On of my favorite methods using a voltmeter is to use a sewing needle to pierce the insulation, and attach the meter lead to the needle for in-circuit measurement. When finished smear some silicone sealer where the needle was. Haven't found a pin-out the C2 connector, will take another look. :cheers: |
PCM C2 pin-out
Found it, PCM C2 pin-out:
https://cimg2.ibsrv.net/gimg/www.jk-...8e5f29b702.jpg |
