P1731 code
Old Mar 15, 2014 | 08:49 PM
Rich6700's Avatar
Default P1731 code
12 jku with 25k trans goes into limp mode. Cleared the the and was able to manually shift the trans but no 4th gear. Anyone else having trans issues on 12s.
Sent from my iPhone using Tapatalk . Rich
Old Mar 15, 2014 | 08:57 PM
ronjenx's Avatar
Have you checked the transmission fluid level?
Are there any other codes present. Use a code reader. Not all codes will show with the self-read feature.
Have you reprogrammed for the bigger tires?
Old Mar 15, 2014 | 09:02 PM
Rich6700's Avatar
Fluids good , one of the other guys I wheel with his jeep is in for a trans at 27k. Was just look to see if there was issues with the 12s
Old Mar 15, 2014 | 09:03 PM
Rich6700's Avatar
The tires have been programmed for over a year now , first issue with the trans.
Old May 19, 2020 | 05:14 PM
Wade Osborne's Avatar
I'm having the same issue ...
What did you do to correct it??
Old Sep 12, 2021 | 11:43 PM
brokat1982's Avatar
Spoiler
Czy udało się Wam zlokalizować przyczynę?
