Paint on mopar rails?
Old May 8, 2013 | 05:22 PM
jeeptk93's Avatar
Default Paint on mopar rails?
I was wondering what type of paint to use on my stock step-bars, since they faded to that awful grey.
Any suggestions??
Old May 8, 2013 | 05:26 PM
RMucho's Avatar
If you mean the oem rails, try krylon paint for metal and plastic. Make sure you wipe it good with like rubbing alcohol and you should be good. Test a spot like underneath before doing the whole thing just to make sure.
Old May 8, 2013 | 05:27 PM
jeeptk93's Avatar
Yes, is there any other prep work involved?
Old May 8, 2013 | 05:35 PM
Flexer07's Avatar
Trim shine from oriellys auto parts should bring in back to black. It's great stuff
Old May 8, 2013 | 06:54 PM
RMucho's Avatar
As long as its very clean of any dirt and other oily residue it should be ok. That's why I would recommend testing a spot first to ensure you get the results you are looking for.
Old May 8, 2013 | 07:10 PM
2yellowlabs's Avatar
Default Krylon Satin Black
Use a green Scotch-brite pad if they aren't rusty. Bought a pair of Rubi rock rails for my Sport that had surface scratches/fade and the Scotch-brite pad/Krylon Satin Black did the trick. Be sure to prep with denatured alcohol or the like after the Scotch-brite treatment and before painting.
