Parts Interchangeability between D30 and D44
Old Dec 9, 2011 | 05:04 AM
JKagermeister's Avatar
Default Parts Interchangeability between D30 and D44
I trashed my Dana 30 this summer and will eventually need to either fix or upgrade axle. See video below. My plan is to purchase a used Rubicon D44.
What parts are swappable between the D30 and Rubi 44?
Can I swap my knuckles, brakes and rotors onto the D44?
If I buy a JK D44 without a carrier and gears, do I have to purchase the JK carrier setup with factory E-locker or can I run an aftermarket locker or none at all?
Can I run standard D44 axles in a JK D44 if I purchase a standard carrier or am I limited to the JK specific carrier and axles?
Will the D44 bolt up in place of my D30?
https://www.jk-forum.com/forums/show...n-you-diagnose
Old Dec 9, 2011 | 05:59 AM
wayoflife's Avatar
JK-Forum Founder
yes, these are exactly the same.
you can install an arb air locker if you want, you just need to make sure that it's for a rubicon.
you will need to run JK specific shafts as they are a specific length and spline count.
yes
Old Dec 9, 2011 | 08:11 AM
Cool. Thanks for the info!
