Parts transfer from 07 to 15?
I'm thinking of trading in my 07 for a 15. Will my Lift kit (2", don't know which one it is) fit the 15? Should I keep the Viper throttle body or let it go with it? Will the CAI transfer over? Thanks for your opinions.
Same as above, but I'll add that if you don't know what lift you have, you probably should get a fresh kit on the new Jk. Unless you dropped some serious coin on the current lift, you're better off leaving it on and not swapping. And if it has been on for any period of time, it could bring the suck to try and remove it. Bolts rust and seize. I just worked on a friends jeep that had the lift on for several years. I broke half the control arm bolts removing them (had to use a 3/4" impact) and a couple I had to cut out with a plasma. At that point it was discovered that the shocks were bad (didn't extend in their own) and that two control arms and the front track bar needed to be replaced.
Thanks for the replies, I don't know which lift is on it because it was already on it when I bought it. I didn't think the engine stuff would transfer because it's a different engine. How about the mopar floor mats? I just bought them, will they transfer over? Thanks again.
