Pentastar in a 2008??
My buddy ran his Jeep low on oil and ruined his engine. He has a 2008 with the 3.8 V6. I was wondering is it possible to put a 2012 3.6L V6 Penta in a 2008?? I know of somebody with a motor and trans, but can it be done?? Thanks
If you have the motor and trans I would think you would need the computer and probably the wiring harness. Being that it hasn't really been done yet I am guessing I would probably try to find a Wrecked Jeep that still has the front end intact (good luck) just so you could pull any small things you need like sensors, brackets, ect.
The Pentastar is a nice factory engine and a big step up from recent Wrangler engines, but if you have to replace the engine *and* all the wiring and harness, I'd go Hemi. Better tested and will cost the same or less.
I would think it would be a lot easier than a hemi or LS swap and cheaper actually depending in how much you spent on the engine, trans, wiring harness, and ecu. Is the engine and tranny mounting any different than the 3.8l?
