Perfect Re-Gearing
Old Feb 1, 2009 | 08:44 PM
Mk-Dubai's Avatar
Question Perfect Re-Gearing
Well im getting my new gears soon...
Its just i feel like im missing something (Damn Gut Feeling), iv got an 07' with 35" and im regearing to 4.56, is there anything else i need to change or add to complete the regearing perfectly?
Old Feb 1, 2009 | 08:46 PM
bigbluejk's Avatar
install kits and pinion bearings. Oh... and taller gears.
Old Feb 1, 2009 | 09:07 PM
Mk-Dubai's Avatar
well this is what iv ordered from quadratec
http://www.quadratec.com/products/52419_95X_C_PG.htm
so i dont really know what im missing, any help on what and where to get the parts would be appreciated.
as for the gears down here its better with the 4.56
Old Feb 1, 2009 | 09:08 PM
Stuka's Avatar
He will be fine with 4.56's, especially if he drives on the freeway a lot. Plenty of guys out there in the 4x4 world running 4.56's with much much larger tires.
But yeah, install kits, and pinion bearings.
EDIT: That link is just the ring and pinion. You will need install kits which have the shims and seals, and pinion bearings to put on the new pinion.
Old Feb 1, 2009 | 09:17 PM
bigbluejk's Avatar
call david at northridge and tell him what you have and what you are doing. he will get you exactly what you need.
Old Feb 1, 2009 | 09:46 PM
Mk-Dubai's Avatar
Ok so iv went and checked and iv found the necessary kits, thanks alot guys, and i have to say this forum is the best where else do you get information this fast.
thanks again guys and good wheelin
Old Feb 1, 2009 | 10:01 PM
bigbluejk's Avatar
do you want to replace all of the bearings and seals in your axles? If you want to and do not mind the cost get the overhaul. If you just want the bear minimum to install a ring and pinion then get the install kits. If you just go install kit then get pinion bearings too.
Old Feb 1, 2009 | 10:19 PM
Mk-Dubai's Avatar
i did that and went with the overhaul kit, thanks again
