perfect tire selection????
Old Mar 30, 2009 | 07:10 PM
tento0929's Avatar
Default perfect tire selection????
hi
i hace the original rims 17'' im buying some tires, i have a 3'' lift and buying some 1''1/4 spacers.
what tire do you recomend to do do off roading and highway miles???
im thinkin in 33''x12.50-17 waht do you think???
they tell me that 35''s whill slow down the car allot, is that true??
any pictures????
my choice intill now is baja claw radial.
thanks everybody
Old Mar 30, 2009 | 07:26 PM
nthinuf's Avatar
'Perfect' for any of us isn't necessarily 'perfect' for you.
Browse here for some background.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
You have the lift, so check out the wheels/tires and axles/gears/drivetrain areas.
That should help you narrow down your choices - and will likely give you many more questions to ask
Old Mar 30, 2009 | 07:49 PM
armycop's Avatar
No one tire is perfect. It depends on your $$$ situation and your driving situation. I have the 315/70/R17 (35") Hankook Dynapro M/T on stock rims. With a 6-speed it is ok, but you lose 6th gear on the highway on hills. If you have an automatic, you may want to stick with 33's or you will feel a loss in power from the bigger tires.
There are many good tire choices, BFGoodrich A/T and KM2, Toyos, Nittos, and the list is huge.
Old Mar 30, 2009 | 09:14 PM
tento0929's Avatar
ok
but whith my 3'' lift an some spacers of 1''1/4 would it clear 12.50 wide???
because i want 33'' 12.50/17 but i dont know if it wont rub at full stering???
and yeah am automatic transmision......
thanks
Old Mar 30, 2009 | 09:31 PM
armycop's Avatar
Yes, with spacers, it will fit a 12.5" tire. You may have to trim or remove the plastic air dam, that is the first thing I tore off when I got my Jeep.
Old Mar 31, 2009 | 08:06 AM
nthinuf's Avatar
Check that link. Lots of really good info there...
Q: What is the biggest size tire I can fit on my stock Jeep JK Wrangler?
A: The largest tire size that the factory recommends is a 255/75R17 (which comes standard on Rubicon models) or a 32x10.50. However, there are many Jeep JK Wrangler owners who are currently running as big as 285/70R17 or 33x10.50's with little to no rubbing issues.
Q: What is the biggest size tire that I can I fit with a 2.5" Budget Boost?
A: 33" without any problems and 35" tires with only minor rubbing at a full flex. Depending on how wide your tires are, you may experience some rubbing at a full turn especially if you did not install an adjustable front track bar and/or are still running factory wheels which have 6.25" of back spacing.
Q: What is the biggest size tire that I can fit with a 3" lift?
A: 35" tires and depending on what lift kit you have, you may still experience some minor rubbing up front at a full flex and when turning.
No one can give you a guarantee that 'your' setup won't rub. But looking at the faq, you can certainly make an educated guess...
