Piaa 520 wiring harness help!!
Old Apr 26, 2013 | 05:47 AM
Brandon09JK's Avatar
Default Piaa 520 wiring harness help!!
I just bout the piaa 520 lights yesterday and ive finally gotten a chance to open the box up. is there any way that i can cut theyre switch off and wire to a rocker switch? and also i have to splice a wire to a power source with a connector that came with the lights...what power source am i suppose to tie that into for mounting them on the windsheild. any help is appreciated!
Old Apr 26, 2013 | 05:59 AM
Sahara_Maverick's Avatar
Does it have a relay? It's one thing I recommend you use.
I installed my 540 using all new switch, wire and relay and kept the original harness in the box. I felt it was a lot easier than trying to make the harness fit through holes and going to the Daystar panel in the central console.
Old Apr 26, 2013 | 06:27 AM
it has the relay and fuse built into it, im just trying to see if i can cut there switch off of it and wire it to a daystar one with the red white and black wires. plus that one floater wire that i have no idea where it goes haha its suppose to power the switch but wouldnt it be gettig power already from the battery? could that wire just be for the switch lighting up?
Old Apr 26, 2013 | 06:31 AM
tapp's Avatar
You can cut the switch off and wire to a day star I did it. The floating wire I think it's white with red stripes I did a fuse tap for it. It's just power for the switch and the day star needs it. And the three wires going in the PIAA switch will match up with the day star. I have a thread made and you can look it it to see what wires go to what wires.
Old Apr 26, 2013 | 06:41 AM
i cant find that thread you were talking about and a fuse tap? im relatively new to wiring so not really sure what your talking about.
Old Apr 27, 2013 | 09:36 AM
The fuse tap you can buy in an auto parts store. It an accessory specially designed to plug in a fuse space. It keeps protecting that circuit but also takes power for the lights. There are different sizes so make sure to see the model your Jeep uses to get the right size.
If your lights' harness does not have fuse protection you should also buy a fuse holder for it and install right after the fuse tap you bought.
Old Apr 27, 2013 | 07:05 PM
Ryan0260's Avatar
Yes, you can easily cut off the included switch and go with a rocker. As far as power, use the included wire tap. The passenger side marker light is easy to access. Just wrap the connection with electrical tape.
