Pics of JK with no front bumper?
Does anyone have pictures of a JK with no front bumper? Reason I ask is that I will want to flat tow it and want to know in advance what's underneath to tie into. Don't want to use the typical brackets made by tow bar companies since they would reduce the approach angle. Is there still a large tube that passes through both frame rails? I used this to tie into for my tow bar attachment point on my TJ.
Thanks!
Thanks!
As you can see in the photo below, there is no longer a front cross member tube on the JK. The frame rails now stick out like two arms and without anything connecting them together.
The lower bar across the bottom of the frame rails is actually pushed back quite a bit and in line with the grill.
From what I have seen, the bar does allow the plastic air dam to be mounted to it but if you have a Rubicon, it looks like it would offer protection to the huge disconnect motor as well.
Am i the only one that thinks that is a silly thing to add, (the electronic disconnect)..
I agree i do like the rok-n-loc set up.
, Once they come out and are proven i might change my mind.
I dont run a sway bar on any of my jeeps, YJ or the TJ on 33's. its easier just to not have to deal with the sway bar.
I have the old SwayLOC on my TJ and can tell you that wheeling with it is far superior to being disconnected or having no swaybar at all. You have all the advantages of maximum flex but with the added feature of stability on the trail.
