Pics of JK with no front bumper?
Does anyone have pictures of a JK with no front bumper? Reason I ask is that I will want to flat tow it and want to know in advance what's underneath to tie into. Don't want to use the typical brackets made by tow bar companies since they would reduce the approach angle. Is there still a large tube that passes through both frame rails? I used this to tie into for my tow bar attachment point on my TJ.
Thanks! |
As you can see in the photo below, there is no longer a front cross member tube on the JK. The frame rails now stick out like two arms and without anything connecting them together.
https://www.jk-forum.com/forums/uplo...k-nobumper.jpg The lower bar across the bottom of the frame rails is actually pushed back quite a bit and in line with the grill. |
Thanks!!
Is the lower cross bar you mention intended to take place of the round tube in the TJ or is it for some other purpose? |
Originally Posted by GJTJ
(Post 1408)
Thanks!!
Is the lower cross bar you mention intended to take place of the round tube in the TJ or is it for some other purpose? It just suports the plastic skidplate. |
Some other thread mentions the lower bar being related to the european pedestrian requirements. Which means hack it off in the US.
From what I have seen, the bar does allow the plastic air dam to be mounted to it but if you have a Rubicon, it looks like it would offer protection to the huge disconnect motor as well.
http://www.project-jk.com/gallery2/m...41a27ed6060625 |
(Post 1485)
http://www.project-jk.com/gallery2/m...41a27ed6060625 Am i the only one that thinks that is a silly thing to add, (the electronic disconnect).. |
Originally Posted by Piginajeep
(Post 1489)
(Post 1496)
I don't know, it's kind of a nifty idea but I'd much rather have a dual rate sway bar system like the Rok-n-Lok. :yup:
I agree i do like the rok-n-loc set up. , Once they come out and are proven i might change my mind. I dont run a sway bar on any of my jeeps, YJ or the TJ on 33's. its easier just to not have to deal with the sway bar. |
(Post 1498)
| All times are GMT -8. The time now is 04:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
