Pinch Seem How to?
Old Jun 8, 2011 | 05:32 AM
speed2005's Avatar
Default Pinch Seem How to?
Where is the how to on bending or cutting the pinch seem?
I know it’s “easy” but want to make sure I don’t mess something up.
Old Jun 8, 2011 | 05:44 AM
smellytuna's Avatar
Interested also to know. Don't want to hi-jack your thread, but I wiill remove my side step soon to install rubi rails. So would like to cut the pinch seem at the same time. But don't want to remove to much. Heard to fit Poison Spyder Crusher Flares, if you cut to much, you will miss material for a bolt in this area?? So if some people have some dimensions to provide... please
thanx
Old Jun 8, 2011 | 05:46 AM
jeep2007's Avatar
You can use a cutting wheel on a grinder or die grinder or a sawzall to cut it in 5 minutes. It will be the shape of a triangle you cut off. Touch the paint up with your choice. I used bedliner on them. A big hammer will allow you to pound the corners over. There are some threads you can read for more info.
Very easy.
Old Jun 8, 2011 | 05:48 AM
JAFHR's Avatar
Just put in "cutting the pinch seam" under the search. You'll come up with several threads on it. I've pretty much read them all as I want to do it too. Sawzall seems to be the tool of choice. You can also use a Jigsaw. Guys also cut their stock rock rail at the same time
Old Jun 8, 2011 | 06:04 AM
greenenvey's Avatar
i read a thread were a guy removed the rear wheels and put the jeep on stands, them removed the rails and trimmed the rails.. Is that really nessecary? If it is im not lazy and ill do it but i just think it can be done with the tires on?
Old Jun 8, 2011 | 06:15 AM
speed2005's Avatar
I have done that and just found a bunch of talk. No step by step how to. Also did a google search and found a bunch of threads but no instructional step by step with pics (I don’t want to cut too much)
Old Jun 8, 2011 | 06:31 AM
jsears's Avatar
I cut my pinch seam with the tires on, be prepared for a small workspace and make sure you don't cut your tire. If you have rubi rails I would definitely take them off before cutting them and the pinch seam.
Old Jun 8, 2011 | 06:50 AM
chipmaker's Avatar
You guys are cutting the pinch seams for 35's? Mine is close, but not that close...
Old Jun 8, 2011 | 06:56 AM
greenenvey's Avatar
Oh yeah I'll diffently remove the rails first!! Good to know thanks!
Old Jun 8, 2011 | 08:23 AM
SBEII's Avatar
According to his profile, he's running 315s on stock suspension. I think most people who trim the pinch seam are running a lot more tire than their lift will allow. You have 2.5" lift and the same tire size. Planman has several threads on how to run BIG tires on minimal lift. I believe he is running 37" on a 2.5" lift and 1" body lift.
