Pitman/drag won't separate!!
I'm trying to install the RC 4" lift on my 2008 2wd Sahara Unlimited and the pitman arm and drag link will not separate. Tried the pickle fork and 3lb hammer---nothing. I have spread 2 pickle forks to no avail. I tried soaking the joint with liquid wrench for a day then tapping around the joint with the 3 lb hammer---nothing. You cannot get a small TRE puller in that small space; I've tried.
Any suggestions??
Any suggestions??
Any suggestions??
Any suggestions??
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1752
The pitman arm is still on the steering box.
My problem is getting out the tapered end of the ball joint that connects the drag link to the pitman arm. The step-by-step directions by Way of Life on project-jk.com say that you can separate the drag link from the pitman arm using a pickle fork and a hammer. Let me tell you, I have completely spread the tines of two pickle forks trying to do it that way. It aint happening...
can you remove the pitman or not? if so i would advise taking it off and maybe torching it then or a few really hard side blows with the 3lb but only one it is off, you do not want to damage to the stearing box or shaft. I think Redneck is right on that and he has like 30yrs of monkey wrenchin under his belt.
You know spit and ducktape would fix that seal.
