Is the Plastic Engine Cover Necessary?
Old Oct 18, 2013 | 09:36 PM
Grn Jeep's Avatar
Default Is the Plastic Engine Cover Necessary?
Has anyone livimg in a high temp area like Arizona found a lower engime temp with plastic engine cover removed? Does it serve any real purpose?
Old Oct 18, 2013 | 10:01 PM
D_engel's Avatar
Its a water cooled engine so it really wont make any difference. You would have to add hood louvers at the least to see any noticeable difference.
Old Oct 18, 2013 | 10:07 PM
Tooadvanced's Avatar
I disagree. You ever felt engine cover after trail riding? There is a reason they leave em off fleet vehicles and its not cost. I've noticed a lot less heat waves coming off hood when trail riding since I removed mine
Old Oct 18, 2013 | 10:16 PM
MarineArmyJeeper's Avatar
I'd imagine that it wouldn't change temps that drastically. if the cover is hot, it's because it's absorbing/displacing heat in my opinion. . But if I was trying to reduce heat, I'd think a more efficient radiator would be most effective, followed by more ventilation [ie- hood vents].. Then again, I'm no master mechanic..
Old Oct 19, 2013 | 12:41 AM
JK-Willy's Avatar
I removed mine and it dropped the engine temp 10 deg or better and now there is no more melting plastic smell on a long day of wheeling.
Old Oct 19, 2013 | 02:08 AM
ronjenx's Avatar
If you have an electric fan, removing the cover won't do much to lower the engine temp. It will still range from thermostat temp to fan on temp. In the case of the 3.8, that's 195°F to 215°F. The 3.6 will be similar.
Now, adding a mechanical fan, which runs all the time, will keep the engine down to thermostat temp all the time.
Old Oct 19, 2013 | 03:24 AM
MOPWR2U's Avatar
The purpose of the engine cover is to reduce engine noise. Remove it if you want. You may notice a bit more engine noise, but I don't think it will affect engine operating temperature significantly.
Old Oct 19, 2013 | 04:26 AM
Gforce!'s Avatar
From: Independence and Lexington, KY (depends on the time of year)
Jeeps have engine covers? Mine didn't come with one...2011
Old Oct 19, 2013 | 04:29 AM
jbry311's Avatar
Because you have a 3.8.
Old Oct 19, 2013 | 04:39 AM
Jersey_Devil's Avatar
Yea.... We're cool.... We don't need one on our 3.8s!lol
Sent from my obama monitoring device
