Play in the front diff?!
Old Apr 13, 2016 | 05:08 PM
jedg's Avatar
Vet Army
Default Play in the front diff?!
So I'm doing some maintenance and noticed this play in my front drive shaft... is this normal?! This is with the tires on the ground.
https://youtu.be/RlMsU04U9TI
Old Apr 13, 2016 | 05:11 PM
PsychoCupcake's Avatar
I could be wrong but I thought some amount of play was normal as it would correspond with the backlash in the gears. I don't know how much is normal though.
Old Apr 13, 2016 | 05:12 PM
jedg's Avatar
Vet Army
Yeah, I'm hoping that is the case... HOPING.
Old Apr 13, 2016 | 05:58 PM
ronjenx's Avatar
As mentioned, there is some required play between the ring and pinion. Most of the slack you see in the video is the play between the differential pinion gears (spider gears) and the side gears they mesh with. Add to that some play in the side gear and axle shaft splines.
Edit to add:
Even though it's 28°F here tonight, I went out and checked my 2008 JK's front drive shaft for the same play you demonstrated in your video.
Mine is about the same.
Old Apr 13, 2016 | 06:48 PM
scooby snacks's Avatar
I have some play... I will check it in the morning and let you know if it is similar...
Old Apr 13, 2016 | 06:54 PM
Joe_B's Avatar
You're fine.
