play in front driveshaft.
Old Sep 1, 2012 | 06:53 PM
silverbackjk's Avatar
Default play in front driveshaft.
I have play in my front coast driveshaft where it meets the transfer case. It just does not have any play on the pumkin side. I also have a clicking sound only when in 4lo.
Old Sep 1, 2012 | 07:29 PM
Rich6700's Avatar
Sounds like the cardigan joint is bad. Send it back to be repaired.
Old Sep 1, 2012 | 07:36 PM
JKZinger's Avatar
It would click in 2 WD and in high range if it was a Cardin joint. Pull the driveshaft off and see if the clicking goes away in low range. Takes 10 minutes to pull it off.
Old Sep 3, 2012 | 06:16 PM
I will give it a try this week. While it off should i check the the torque on the nut that hold the yoke on? this problem is driving me crazy.
