play in steering?
Old Mar 24, 2011 | 08:47 PM
jtjk's Avatar
Default play in steering?
after lifting my jk i find that there is lots of play in the steering by this i mean i can move the wheel quite a bit before the wheels turn.
I have done a search and cant find anything, im sure this has been asked a million times and im just not understanding or using the right terminology. is this the caster being wrong, steering stabilizer, track bar ??
i dont believe that it is due to anything being broken it is simply because i have a very simple lift.
Thanks !
Old Mar 24, 2011 | 08:50 PM
Pluke the 2's Avatar
did you make sure that you connected your sway bar links back up?
Old Mar 24, 2011 | 08:52 PM
if you added the 35" km2s at the same time as your suspension upgrade. triple check that you have about an 1/8" of "toe in" and this will def make your steering a night and day difference...
Old Mar 24, 2011 | 08:54 PM
jtjk's Avatar
im pretty sure the track bar was installed properly, though i did not do the install. i ran the stock tires for about a month before going to 35's. what do u mean by toe in?
Old Mar 24, 2011 | 08:57 PM
cfr's Avatar
cfr
It's an alignment spec. Search the write-ups for the garage alignment.
Old Mar 24, 2011 | 09:05 PM
jtjk's Avatar
great, i checked out the write up and will give that a shot tomorrow and see if it helps.
Old Mar 24, 2011 | 09:08 PM
check out azjeepers info on this thread:
https://www.jk-forum.com/forums/show...correct-Toe-In
Old Dec 20, 2011 | 09:17 AM
brink2177's Avatar
I am having this same problem. Did you adjust the toe-in to fix it?
Old Dec 20, 2011 | 11:13 PM
jtjk's Avatar
Back from the dead thread!
In the end i dont know what changed. i switched tires, changed caster, changes steering stabiliers, new alignment done, re bolted my track bar, added a body lift. and the problem was gone. not sure which one did it as it was all done at once.
I have learnt that the jk do have some play in the steering naturally. i know that does not help, sorry.
Old Dec 21, 2011 | 08:47 PM
brink2177's Avatar
Thanks, I went through and torqued everything back down after putting about 200 miles on the Jeep, and now everything feels a lot better! I think it took care of any issues I was having!
