Please help
Old Jun 18, 2011 | 08:42 AM
JVIGI317's Avatar
Default Please help
I HAVE A 2010 WRANGLER SAHARA UNLIM.4DR i DID AND AIRRAID INTAKE AND EXHAUST.......LOOKING TO DO A CHIP.....SHOULD I GET THE JET STAGE 1 OR SUPERCHIP? I ALSO AM RUNNING LARGER TIRES.
Old Jun 18, 2011 | 08:45 AM
Mark Doiron's Avatar
I don't think that the Jet Stage 1 will let you do anything but change the Jeep's tuning. Most of the programmers let you adjust other features such as tire size, TPMS setting, etc. This varies by programmer. You should learn what the features of each programmer are versus your needs (do you plan to go larger than 32s, for example?) to determine which one is best for your needs. Right now, there are about a half dozen or more programmers available for the JKs. There are quite a few threads on these--to learn more suggest you read threads you hit after searching on "Superchips", "Hypertech", "Bully Dog", and "AEV Procal".
Old Jun 18, 2011 | 09:01 AM
JVIGI317's Avatar
Default Thanks for the response
Originally Posted by mark doiron
i don't think that the jet stage 1 will let you do anything but change the jeep's tuning. Most of the programmers let you adjust other features such as tire size, tpms setting, etc. This varies by programmer. You should learn what the features of each programmer are versus your needs (do you plan to go larger than 32s, for example?) to determine which one is best for your needs. Right now, there are about a half dozen or more programmers available for the jks. There are quite a few threads on these--to learn more suggest you read threads you hit after searching on "superchips", "hypertech", "bully dog", and "aev procal".
not looking to run larger tires.....i feel like the intake or exhaust has changed something....when i accelerate it feels like its shifting ? I have to keep stomping on it. I was thinking that a chip may help adjust things? I appreciate the info.
