Poison spyder rear bumper HELP !!!
Old 10-19-2014, 04:42 PM
Seabee CMC's Avatar
Do you have to reinstall the rubber bump stops that are originally on the tailgate that the tire presses up against?
CajunTiger's Avatar
I'm missing a pic to understand what's wrong...your recent pics show a big gap between the tire and your tailgate. I have an earlier tire carrier but it should be basic to what I have. Can you take a pic of the whole backside of the jeep for me?
Sent from the swamp while taggin' a gator!
Old 10-19-2014, 04:43 PM
CajunTiger's Avatar
I had to trim mine down for my tire to fit....just sayin'...
Invest2m4's Avatar
Originally Posted by JackDANJK22
The plates bottom out on each other at each end ... & doesn't look like much material would be left ...
Call them tomorrow. As I mentioned, my carrier works the same way and I had to cut the brackets down so I could slide them in further. You don't want to cut into the slots though and it doesn't look like you have much room to cut. They may need to send you out a new bracket.
Are you running super narrow tires? Looks to me like the problem is that your tires are too small
Old 10-19-2014, 04:44 PM
Broncorif's Avatar
The picture looks like the plate could be rotated 90 degrees because the top slot looks longer than the side slot. I have no experience with this set up, just what it looks like in the picture.
Old 10-19-2014, 04:45 PM
CajunTiger's Avatar
That was gonna be my next comment....cheers
Old 10-19-2014, 04:53 PM
JackDANJK22's Avatar
I don't see how they would help , or allow the carrier to close
That hole would be where the rubber bump would go into ....
Old 10-19-2014, 04:55 PM
[QUOTE="CajunTiger;3998857"]I'm missing a pic to understand what's wrong...your recent pics show a big gap between the tire and your tailgate. I have an earlier tire carrier but it should be basic to what I have. Can you take a pic of the whole backside of the jeep for me? Sent from the swamp while taggin' a gator![/QUOTE
That gap , is my problem . I cannot draw the tire in close enough to tighten against the carrier rails .
Old 10-19-2014, 04:59 PM
Call them tomorrow. As I mentioned, my carrier works the same way and I had to cut the brackets down so I could slide them in further. You don't want to cut into the slots though and it doesn't look like you have much room to cut. They may need to send you out a new bracket. Are you running super narrow tires? Looks to me like the problem is that your tires are too small
I will ca tomorrow and ask ... See what kind of light they can give me , I don't feel good about cutting Into them either .... Not much left to do so
The tires are 285/70R17s on 4.5 bs ...
I have a feeling that is the issue ....
Woulda been a nice heads up that there is a tire size minimal requirement ! ....
Old 10-19-2014, 05:07 PM
It was a good call ! One that I thought could save my day , I put only the top bolt in to see if it would give me enough ... And then in theory tighten the sides up where ever they land .... But no success .... : (
Quick Reply: Poison spyder rear bumper HELP !!!
