Popping noise
I installed a TF 2.5 coil lift with shock adapters on my 09. When I make sharp turns left or right I hear a popping noise coming from the front suspension. I had someone turn my wheel left and right and isolated the noise coming from the front springs. When the wheel is turned left or right sharply I can see the spring flex alittle and I can hear the popping noise. I seated the springs correctly and put the isolators on when I installed the new springs. I figured since the springs were longer they would flex alittle and the noise might just be normal with the longer springs. The springs have not shifted from the bottom perch and the last coil is in that groove on the perch. Anyone have anything similar? Yes, I did re-torque everything and everything was fine. It's not affecting the driveability, just an annoying sound, but probably unavoidable.
