popping noise!?
Old Jul 31, 2011 | 03:41 AM
robsjeep9's Avatar
JK-Forum Ambassador
Originally Posted by jktoy
Did it sound like it was right under your seat.
Kinda the driver side seat..... More so front driver side tire area... Good luck.
Old Jul 31, 2011 | 04:10 AM
woodweavil's Avatar
Take this how you want to! I had the same thing. I could not find it to save my life! until the front diff locked up( couple months later) turns out it was a chipped tooth on my ring gear! Easy check. Just change your diff fluid and look at the magnetic plug! My guess is you will have a piece of tooth stuck to it! let us know if this is the problem or not
Old Jul 31, 2011 | 04:37 AM
jktoy's Avatar
I don't think that is it. But u never know. But I am planning on changing the fluid out in it Monday anyway so I will be sure to let u guys know.
I noticed on my way home this morning. That it only really does it when I'm going slow and over bumps. I put it in 4lo and hi when I got home and it didn't do it. But I don't go over any bumps
Old Jul 31, 2011 | 07:20 AM
robsjeep9's Avatar
JK-Forum Ambassador
I just put new gears 5.13 Yukon in May went back in June for diff fluid change all ok..... Last week went back for noise checked a bunch of things.... Nothing until we removed front drivesaft..... No more noise..... Getting a new Tom Woods!!!
Old Jul 31, 2011 | 08:49 AM
Blakspire's Avatar
Am I the only one thinking coil pop here?
Old Jul 31, 2011 | 12:57 PM
jktoy's Avatar
[QUOTE="Blakspire"]Am I the only one thinking coil pop here?[/QU
What do u mean?
Old Aug 7, 2011 | 09:35 PM
Blakspire's Avatar
Coil pop is a popping sound that comes from a coil spring cycling. perfectly normal. Just a thought.
Old Aug 8, 2011 | 04:13 AM
WhiskyPirate's Avatar
I'm trying to track down my own popping sound right now. Took the Jeep out wheeling for first time yesterday since the new RK lift (had bb in before) and I would get a loud pop or snapping sound from front driver side once in a while. Only seemed to to do it when I had a decent amount of flex going on. Never heard the sound before until yesterday and I disconnected. Looked all over for anything that looked out of place and found nothing. Thinking it may be the coil popping, but maybe pre-load in the trackbar or lower control arms since all of that was replaced?...
Old Aug 8, 2011 | 08:00 AM
jeeeep's Avatar
Coils - have you check to make sure your coils are seated properly top and bottom? if they aren't , they'll pop.
look at the sway bar links, make sure they are on the corect side of the axle mount to sway bar if they aren't they will bind. last, I trimmed a couple of the bolts that I noticed after lifting where I was concerned they might catch the solid breake lines on articulation. more ideas to check out
Old Aug 8, 2011 | 08:05 AM
Policejeep's Avatar
Do you have a receiver hitch. If so take it out and see if it does it.
